| Message |
i installed an RPS max series pressure plate with street disc at 73k and now at 97k my clutch is slipping really bad, especially uphill and when in fourth gear. i suspect the disc is worn out. is that normal lifespan for this particular product? i imagine the max series pressure plate is rock solid and can be re-used, so i don't want to buy a whole new clutch kit. can i just get some cheap OEM replacement friction disc on ebay and use it with my upgraded pressure plate? with my mods? (bolt on mods with boost set to 14 psi) i don't want to replace the clutch again for at least 50k, i'm very disappointed but i'm not sure if it's normal. what do you recommend for me to purchase? TIA.
